Welcome to Naviate Tech Preview - our space for experimentation, ideas, and early innovation. Here you’ll find everything from quick prototypes and vibecoded apps to early concepts and product explorations not yet part of our official offerings.
This is where we test, learn, and evolve—together with you. We invite you to explore, try things out, and most importantly, share your feedback. Your insights help shape what comes next in Naviate.
Automate structural element splitting in Revit.
During the conceptual and early design stages, Revit models often contain walls, columns, beams, and floors that extend across multiple storeys or span several grid intersections. While this approach is ideal for rapid model development, these elements typically need to be split as the design progresses.
On medium and large projects, manually splitting walls, columns and framing can consume several hours per revision cycle, introducing inconsistencies and reducing valuable modelling time.
The Solution
Split Structure is a Revit add-in that automates element splitting in seconds. Select your elements, choose your levels or intersection points, and click Split. The add-in handles the rest, preserving family types, data, level constraints, and offsets throughout.
Key features
- Split Walls and Columns - Split multi-storey walls and structural columns at any combination of project levels. Choose your target levels from a visual list and apply with a single click.
- Split Floors - Divide floor slabs along selected grid lines or named reference planes into separate regions, ideal for phasing, RC Detailing, structural analysis export, and coordination.
- Split Beams at Columns - Automatically split structural framing at every column centreline intersection. Works across the whole model or on a user-defined selection of beams and columns.
Why choose Split Structure
Save hours per model
What takes an hour manually takes seconds. Free your technicians for higher-value work. Model Quality You Can Trust.
Symbols are preserved automatically
Level constraints, base/top offsets, and family symbols are preserved automatically, no rework. Works on Your Whole Model or a Selection. Process every element at once or be surgical. Your choice.
Compatibility
Compatible with Autodesk Revit 2024 - 2026. Supports steel, timber. concrete, and composite structural families. Works with both structural and architectural column categories.
Split Structure - an overview
Download here
Resources
