Welcome to Naviate Tech Preview - our space for experimentation, ideas, and early innovation. Here you’ll find everything from quick prototypes and vibecoded apps to early concepts and product explorations not yet part of our official offerings.
This is where we test, learn, and evolve—together with you. We invite you to explore, try things out, and most importantly, share your feedback. Your insights help shape what comes next in Naviate.
Shape terrain around buildings in Revit
The challenge
When a building is placed on a site, the surrounding terrain needs to be adjusted. This often means creating an excavation area beneath the foundations and connecting it to the existing ground with slopes.
In Revit, this usually requires manually editing toposolid points and calculating where each slope meets the terrain. On uneven sites, some areas need to be cut while others need to be filled. If the building moves or its elevation changes, much of the work must be repeated.
The solution
Cut & Fill reshapes the toposolid automatically. Select the toposolid and the building elements. The add-in creates a flat area beneath the building footprint and slopes it out to the existing terrain. Where the terrain is higher, material is cut. Where it is lower, material is filled.
Key features
Cut & Fill by element, face, or edge
Use the bottom faces of elements as the building footprint. You can also select individual faces or closed loops of edges.
Automatic slope markings
Create long and short slope ticks between the top and bottom of each slope after each run.
Create toposolids from DWG
Link a 3D DWG, such as a ground model from Civil 3D, and preview it in 3D before creating the toposolid.
Select which layers to include and create the toposolid from:
- 3D faces
- Contour lines
If the ground model changes, reload the DWG and update the toposolid. Updating replaces the toposolid, so run Cut & Fill again afterwards.
Why choose Cut & Fill?
From hours to seconds
No more moving toposolid points one by one. Move the building, run the command again on the original terrain, and the terrain follows.
Cut and fill in one operation
The add-in determines whether the slope should go up or down at each point along the footprint. This makes it possible to handle sloping and uneven sites without separate operations.
From civil model to Revit
Bring a ground model from Civil 3D into Revit as a toposolid, then shape the terrain around the building using the same workflow.
Compatibility
Compatible with Autodesk Revit 2025 - 2027. Works on Revit toposolids, with floors, structural foundations, family instances, faces or edges as the footprint. Toposolid from DWG reads linked DWG files with 3D faces or contour lines. Large surfaces are thinned to stay within Revit's toposolid point limit.
Download here
Resources
Toposolid point limit
Revit keeps a limited number of points in a toposolid. If a toposolid is created with more points, Revit removes some of them without warning, which can make the surface less accurate.
Toposolid from DWG reads the limit for your Revit version and stays just below it. When a ground model has more points than the limit allows, the add-in keeps the points that matter most: the outer boundary and the points where the terrain changes shape. The status bar shows when this happens.
From Revit 2026 the default limit is 20,000 points, and you can raise it to as many as 50,000. Close Revit, open %AppData%\Autodesk\Revit\Autodesk Revit 2026\Revit.ini (or the folder for your version), and add or change this line in the [Misc] section:
NativeToposolidMaxPointThreshold=50000
Then start Revit again. More points give a more accurate surface, but toposolids take longer to create and the model gets heavier. In Revit 2025, Cut & Fill uses a limit of 10,000 points.
